Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 10-22-2005, 07:39 PM
RB43 RB43 is offline
Question ground effcts
I've been restoring a 1995 Daytona, i've taking some ground effects off a Daytona Iroc . I have all but one of the pieces , I need the one that goes directly behind the drivers door ,before the rear wheel. I have checked locally and all over the web but no luck. Would really like to locate one so I can finish the car. It looks so cool now , need to get it done.
Old 10-26-2005, 11:40 AM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: ground effcts
how much are u looking to pay?
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 11-05-2005, 08:15 AM
I,m not really sure what the cost of it really is . Would like to keep as low as possible.
Old 01-09-2006, 11:52 AM
GOLIATHGMC GOLIATHGMC is offline
Exclamation ????????
What year is your car??? As far as I knew, Chrysler stopped building Daytonas in 1993. It was replaced with the Avenger. Is your car a 1985??
Old 02-11-2006, 04:59 AM
DodgeDaytonaV6 DodgeDaytonaV6 is offline
Re: ground effcts
Goliath is correct...
Daytona's were made from 84 to 93...
Gen 1 - 4 eyed Daytona's...
Gen 2 - Pop-up headlight daytona's
Gen 3 - wrap around headlight daytona's...
If you are talking about an IROC, then you are referring to the 91-93...
The IROC was only a sticker package for the most part (the same items could be had on an ES model)
Just find yourself a 89-91 ES model if its a 91 daytona or a 92-93 ES if its a 92 or 93 daytona...
1990 Dodge Daytona ES (Parts) | 1993 Dodge Daytona ES (DD/Project Car)
Doing/Done:
4 Wheel Disc Conversion (In progress)| 5 speed manual swap (In progress) | 52 mm Throttle Body | K&N Air Filter
Soon to come:
Underdrive Pulley System | Port & Polish Heads, Intake & Exhaust manifolds, and plenum | 0.040" Venolia Forged Pistons |
3" Catback exhaust (custom mandrel bent) | Custom exhaust manifold and crossover pipe | Garrett TO4E 57 trim | Walbro 255 lph Fuel Pump
