Old 10-22-2005, 07:33 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Brake Qurstions
I changed my brothers brakes today on his 99 GMC Sonoma (American Edition). lol. I've never changed brake before in my life. Ill pull an engine, but I wont touch brakes. Until today. I pulled off the 2 bolts, and pulled the whole caliper off the rotor. Putting it all back all good and all, I have a question.
People usually talk about bleeding the brakes when they done. I didn't have anything like that. I kept the brake line on the caliper. I pumped the brakes when everything was installed, and they worked when pulling into the garage. Did I do something wrong? Also, do I have to take off both bolts on the calipers?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-22-2005, 07:52 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Brake Qurstions
Nope nothing wrong assuming you just replaced the pads.
Did you use any lubricant when you put the old plates on the new brake pads (if you changed the pads that is?)
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 10-22-2005, 08:11 PM
david-b's Avatar
Dave is THAT guy
Re: Brake Qurstions
Yeah. Was I supposed to use alot? I laid alot on the one, and the other one I was kinda generous with.
75 Monte Carlo
Old 10-22-2005, 08:39 PM
Re: Brake Qurstions
as long as you wiped it off from the edges if it came out, its good enuf.
But you did absolutely nothing wrong then
95 Eclipse GS-T
Currently:
Soon lol
Old 10-24-2005, 09:08 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Brake Qurstions
The only thing I have been advised of in the past, is to be careful when compressing the caliper piston on cars with ABS.
Most people recommend that you open the bleeder valve when you compress the piston so the excess fluid exits the system that way, instead of being forced back through the ABS unit.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-24-2005, 03:30 PM
Re: Brake Qurstions
If you carefully use a c clamp and arent retarded then youll be ok
95 Eclipse GS-T
Currently:
Soon lol
