Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-22-2005, 06:43 PM
Nick137 Nick137 is offline
Unhappy Shifting Problem
When I'm driving my car for awhile (20-25 mins, going like 65-70 usually, not sure, I haven't drove around town for along time yet). Lets say I'm on the highway and I have to slow down to go through a town. When I slow down my car will kind of jerk. Then when I try to speed up, my car won't shift, the RPM's just keep going higher and higher until it redlines.(I can go anywhere from 0-70, so I'm assuming like second gear? Not sure, but it redlines at 70 or slightly over) If I put it in park and then put it back into drive, it does nothing. If I turn my car off and turn it back on, it works just fine. My Malfunction Indicator Light is on, but this isn't the first time it has come on. I need to get it looked at. I already know I need a new radiator fan (which I have just need to put it in, and a PCV valve which I will be getting soon since my car has 91k miles). Does anyone know whats wrong with my car? By the way its a 2004 Intreped. I am thinking its a computer problem, but does anyone know? thanks
Old 10-23-2005, 09:35 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Shifting Problem
try turning your key on/off 3xs ending in the "on" position. Look at your odometer display and it should spit out a "P0743" code or something to that effect. It sounds like your output speed sensor could be acting up causing your transmission to go into "limp mode" or your transmission automatically defaults to 2nd gear. Another way to find out why your MIL is on is to go to Autozone or Advance Auto Parts and have them pull the code for you.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-23-2005, 09:37 PM
Is there anything else it could be?Such as something that is going to cost me a lot of money? lol
Old 10-23-2005, 11:14 PM
it could be the solenoid pack, it houses all the solenoids and pressure switches that make the transmission go. Or it also be the Transmission Control Module; you never know until you find out exactly what the codes are.
Old 10-24-2005, 08:23 AM
so what your saying is try that and write down the code and find out what it means?
Old 10-24-2005, 09:32 PM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
This site tells u the codes' meanings:
http://glen.utdallas.edu/Cathy/1999%...id%20Codes.htm
car audio guru...
