Old 10-22-2005, 06:53 PM
alh27 alh27 is offline
Question Lots Of Noise Coming From my Head ex Pinging, Ticking
ive got a 88 crx si and recently blew i hole in the side of it with one of my rods. so i got a block from a 92 dx and used my head from the 88 si. ive got it all back together now and the things is pinging and ticking like crazy ive been reading all the other threads and there are things about timing and setting the valves and what not. IVE DONE IT ALL. ive completely re-Timed the thing at least 20 times just to make sure it was right. and still the super loud ticking. its definatly coming from the head. it does it all the time even when it idles and just ticks faster when i accelerate. ive put about $800 rebuilding the block and head. and now this. and also i just recently put a new dist cap and rotor in and i went back in to check them and the rotor was completely melted and driping. please somebody give me some advise other then the timing being off or the valves not being spaced right. oh yeah definernt grade gas does nothing!
Old 10-22-2005, 06:57 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Lots Of Noise Coming From my Head ex Pinging, Ticking
Need to adjust the rocker arms to the correct valve lash.
Also, did you check to see if your valves were bent when you had the head off?
Old 10-22-2005, 08:10 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Is the head overheating due to lack of oil or coolant? GL
Old 10-22-2005, 10:44 PM
i dont see how the rocker arms what be different they worked fine before. i and went through the valves and checked them before installing the head they looked great. the oil circulation is fine as well as the coolant
Old 10-23-2005, 02:01 AM
Hybrid1990crx's Avatar
its because you are using a 92 block i think.
Old 10-23-2005, 04:24 AM
03TRDTacoma's Avatar
03TRDTacoma 03TRDTacoma is offline
the block has nothing to do with it. you can use a block from a 99 and it wouldnt matter. anyways, with as much as youre spending on that motor, you might as well consider a different one all together.
2004 Toyota Tacoma 4x4
1990 Eagle Talon TSi AWD
2002 Suzuki GSX-R 600
Old 10-23-2005, 06:03 AM
greatandmighty1 greatandmighty1 is offline
Re: Re: Lots Of Noise Coming From my Head ex Pinging, Ticking
a block from a 99 has the crank sensor in it. the obd0 does not.
Old 10-23-2005, 10:50 AM
johnb16a2's Avatar
You said the rotor melted? Like put in a toaster oven melted? Something is def getting overheated then. Got pics?
Old 10-23-2005, 11:03 AM
yes like put in a toaster oven melted. i didnt even know those things could melt. i dont have any pics because i took it back to the auto parts store and they gave me a new one.
Old 10-23-2005, 11:04 AM
i would love to go get a new motor but throwing $800 in the garbage. i dont think i can do that
Old 10-23-2005, 02:46 PM
then why when using a 92+ head and a 88-91 block you have have to use a adj. cam gear?
Old 10-23-2005, 06:04 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
do you have oil pressure ? take the valve cover off and start the engine, you should see oil flying around, if you dont then your head isnt getting oil or you got no oil pressure.
Team Lonely Drivers
Old 10-23-2005, 09:19 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 10-24-2005, 10:40 AM
well i took the valve cover off yesterday and theres oil all in the head so i know its getting there.
Old 10-24-2005, 04:58 PM
i would figure out why your rotor melted, i mean it must be pretty hot to melt your rotor. ignition coil or igniter getting really hot ?
Team Lonely Drivers
