Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 10-22-2005, 05:42 PM
menriquez menriquez is offline
'97 concorde nutin' but problems
we bought a 97' concorde from my mom after my dad passed and this piece of crap has been nothing but HUGE headache from the moment we hit 90k...but anyway, here is the latest problem (after we have pretty much replaced everything on it over the past 18 months).
The check engine light has come on and the engine is bogging at about 40 mph and a little at startup. The "key code trick" seems to give 1243, although I don't claim to be a gearhead when it comes to reading this.
Looking up this code, it seems to related to a turbocharger problem, but I wasn't aware that this model even HAS a turbocharge...but then again I don't claim to understand all of this.
Can anyone help me with a little bit of understanding here?
advTHANSance,
- mark
Old 10-23-2005, 11:21 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: '97 concorde nutin' but problems
the 1243 are two seperate codes, the 12 means the battery has been disconnected w/in the last 50 start ups. 43 means you have a misfire in one or more cylinders. If you have the 3.5 V6, chances are, your intake manifold gasket has failed, common problem on the 3.5 V6 engines. You don't have a turbo, so that's not even an issue for you.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-24-2005, 09:43 AM
Re: Re: '97 concorde nutin' but problems
Wow, that is great info...thanks! Is this the type of repair that a non-pro can handle and do you have a link, or should I let my garage handle this (again)??
What a GREAT resourse this site is. I am glad I found it and thanks to you esp. FREAK!
- mark
Old 10-24-2005, 09:37 PM
you can do it yourself, as long as your patient, take your time and have the right tools, you can do it in about 2-3 hours for a novice. Your car has two seperate intake manifolds, the upper portion, also known as the plenum, and the lower portion. The part that usually fails is the lower portion that attaches to the cylinder head.
Old 10-26-2005, 08:09 PM
Ok, well we took care of replacing the spark plugs, ignition wires, and gasket, but now the code we are getting is 22. I lost the link to the site that listed codes, so can you PLEASE enlighten me with this one?
thanks, again...
Old 10-26-2005, 09:45 PM
your coolant temp sensor is either too high or too low caused by either a bad sensor or it being unplugged. I suggest checking around your upper radiator hose and make sure that electrical connector is plugged in.
Old 10-27-2005, 01:57 PM
Freak, you rock...no, really...you were right I just jiggled the temp sensor wires near the radiator thermostat and the problem has gone away. You have no idea how many points I have scored from my wife with your help! <g>
Thanks, again, and may the karma gods load you up!
