Old 10-22-2005, 12:43 PM
carproblems56 carproblems56 is offline
Coolant change?
I have no heat. The temp guage is ok. If I change the coolant would that help?
Old 10-22-2005, 04:16 PM
waltham41 waltham41 is offline
Re: Coolant change?
If I understand correctly that your temperature gauge is reading in the normal range, then you have a blocked hose going to or from the heater core, a shutoff valve inline with one of those lines is stuck in the closed position, or a door in your ventelating system is not working properly. Hot is hot, no matter if it is new or old antifreeze.
