Old 10-22-2005, 12:36 PM
93buicklesabrelmtd's Avatar
93buicklesabrelmtd 93buicklesabrelmtd is offline
Angry 2nd CV axle in 2 months
The drivers side CV axle was replaced 2 mnths ago, then yesterday, I was changing my engine oil & tranny oil, then noticed the same axle was exposed. The outter boot rubber end where it clamps to the boot slid off, and grease came out.
Am I doing something wrong here? I changed the first time and the second time. Or is it just defective boots? Its under warranty got it from Autozone.
This is only on the driver side. The other side everything is still factory and working find!
What would cause this?
Old 10-22-2005, 01:08 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2nd CV axle in 2 months
Another cheap remanufactured part from Mexico. That is what they call the Auto Zone special! Take it back and you might find one in six, that will last a few months. If it were me, I would get a refund Auto Zone and pay the difference for one at NAPA. If you consider your labor worth anything, you will come out cheaper over the long haul.
Old 10-23-2005, 03:52 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Like HotZ28 said what type of clamps are you using?
If you put another boot on make sure you get the good clamps that require the special crimping pliers and the surface where the boot goes on the joint is free from grease.
Regards
Dan
Old 10-24-2005, 09:59 AM
Re: Re: 2nd CV axle in 2 months
Regards
Dan
I still havent fixed it yet.
But its was a whole new axle I put on there twice!
I have under warranty, so maybe the new one wont be messed up. I will have to inspect it at the store.
Old 10-27-2005, 06:26 PM
Re: Re: Re: 2nd CV axle in 2 months
Well if you replaced the whole axel, youi're not responable to check the boots. They should be well clamped when they're installed.
Regards
Dan
