Go Back   Automotive Forums Car Chat > Subaru > General Discussion
Old 10-22-2005, 11:01 AM
ellets ellets is offline
flat response in engine
My 1988 d/l has a strange problem. At cruise it will tend to miss or buck. just a slight increase of throttle will pick up and run fine until cruise is again reached. Have replaced ecm,throttle body and fuel injector,tempsensor. no codes showing. Haven't checked throttle position sensor yet. Been to busy trying to replace head gaskets and valve job on *&^%$#@! mazda mpv.
Old 10-22-2005, 03:43 PM
Vidar Vidar is offline
Have you tried replacing the fuel filter and sparkplugs?
Old 10-28-2005, 07:20 PM
Re: flat response in engine
Plugs are new but I don't recall when fuel filter was replaced. Will also check fuel pump output but it does run fine under heavy throttle.
Old 04-04-2006, 09:18 PM
93loyalewagon 93loyalewagon is offline
Thumbs down Re: flat response in engine
i'm having the same problem with my 93 Loyale. it will run fine but when cruising it will feel like its cutting out or missing.....spark plugs and fuel filter changed 8/05 and everything seems fine, other than this.
