Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-22-2005, 01:08 AM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
no tach...no power..help!!
i have a 93 si del sol i blew the first motor which was a z6 and i put a new one in (z6) and i when i started it it ran and drove fine then the distributor went out so i bought a new one and put it on and the rotor in it went bad then i had the buy a new cap and after all said and done i didnt have really any bottom end power till i got to like 3000rpms then it goes fine...then i change the distrubutor again and it still does the same thing but this time after it was done the tach didnt work so wtf is goin on any help on that would be cool thanx...
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 10-22-2005, 01:44 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: no tach...no power..help!!
is your distributor on correctly? It could be turned 120 degrees the wrong way, which would make that happen. Also, check your distributor wiring harness (not the plug wires, the harness itself)
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 10-22-2005, 08:36 PM
eurobeaner's Avatar
how could you tell ive tried everything.what about an o2 sensor being bad or a plugged up cat?
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 10-23-2005, 10:56 AM
94SolGrl's Avatar
could very well be your o2 sensor.. might wanna try seafoaming your motor... gets the carbon buildup out.
http://honda-tech.com/zerothread?id=1215326
there's the link for how to do it. and to check and make sure your distributor is in the right place, there's a ridge and a thing that looks like an extra plug or something on your distributor cap... that ridge should be pointing to the front of the car. not down, not the back... to the front.
~*Emily*~
HOW TO POST PICS!
