Old 10-21-2005, 10:55 PM
Damarr30's Avatar
Damarr30 Damarr30 is offline
Send a message via Yahoo to Damarr30
Question Clutch or Slave Cylinder??
Hi, I have a 1995 S-10 4cyl 5 speed. My problem is when I head out to go anywhere the clutch pedal works fine. If I drive it more than 20 minutes, the clutch pedal is real hard to depress and it is very difficult to shift. If driven more than 20 minutes, might as well forget about shifting, the pedal is too stiff and it's real hard to get it out of one gear or another. After it cools down for a couple of hours, it works fine again. Would it be clutch or slave cylinder or something else? Thanks for any help.
Old 10-21-2005, 11:27 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Clutch or Slave Cylinder??
I would just try bleeding the clutch and see what happens. Your problem might just go away.
I've never heard or seen a clutch act like that, and other than the fluid being really dirty I won't try to guess.
Old 11-19-2005, 06:06 AM
Damarr30's Avatar
Well I bled the clutch and still the same. So went out and bought a slave cylinder, changed it, bled it, and still the same. Someone said it could be the pressure plate. Any help would be appreciated. Thanks.
Old 11-19-2005, 09:51 AM
Jerry80871852 Jerry80871852 is offline
Could be the pressure plate, could be the throw out bearing froze up, and I suppose it could be the arm that runs to the throw out bearing is froze up for some reason.
I had an 85 Blazer 5 speed manual, 2.8 engine. Never had no clutch troubles, but had much trouble with the slave cylinder and transmission.
Replace the slave cylinder about 4 times, completely replaced the transmission once, seems the 85's has a very sorry transmission, if one has trouble with it, you throw it away and get a new one.
Have a great day,
Jerry
1992 Chevy S-10 Blazer
4 X 4, 4.3 W engine 3.42 gears
172,000 & still going
Sold
2010 Toyota Tacoma Double Cab 4X4 V6
4.0 V6 DOHC 24V VVT-i 236HP Engine
12,000 plus miles
Bought 10-22-11-2001 Toyota Camry LE SuperWhite 4 Door sedan I-4 89,680 miles
