Old 10-21-2005, 09:57 PM
andrew85 andrew85 is offline
my rear end
not my butt on my car. I have an 85 LS camaro that had a 2.8L in it and instead of rebuilding that piece i put a rebuilt 350 with a 4 barrel carb in it.The only problem i had was i had to grind off some steel bars on the engine mounts. No problem. But now I have to get a new hood because i cant put the breater on but more important everyone tells me i have to replace the rear end too. Otherwise the first time i stomp it ill blow out the rear end. Now Im only 17 and ive done everything bymyself so far (pulling 2.8 out, putting 350 in,wiring it up , and getting it running) and that was no proplem. but i dont know anything onrear ends and i want to know what to put in it that will last through my crap but not something for a wheelie car thats going to kill me on gas. And is this going to be a pain to replace.
Old 10-21-2005, 10:33 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: my rear end
you basically need a better or larger gear combo to make it work, v8 engines had atleat a 2.73 to 1 gear ratio in them, i had a better explanation but some how some jacki chan chit popped up, i'm confuded.
Old 10-22-2005, 12:48 PM
I-ROC KID I-ROC KID is offline
Re: my rear end
yah i put 3.73 posi on my car from the old one spinner and it sooooo much of a difference i didn't do it do i don't know how but it costed me like 1300 bucks cdn parts and labour
355 small block 4 bolt, 700R4 tranny/w shift kit, elbrock 650 carb, elbrock intake, mild cam, 3.73 posi rear end, 3" cowl hood, 3" exhust, b&m mega shifter, k&n air filter, ac delete
Old 10-22-2005, 06:20 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
i thought it was going to be a picture of his ass
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 10-22-2005, 07:33 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: my rear end
you're not disappointed are you??
Old 10-22-2005, 08:56 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: my rear end
lol, i would find a parts car to take a rear end off of.
Old 10-22-2005, 09:09 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: my rear end
get a rear off of an LT1 4th gen, 3.42s should be good for you
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 10-23-2005, 12:44 AM
1986Z28's Avatar
Has a Camaro
Re: Re: my rear end
no... jkjk
Old 10-23-2005, 08:23 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: my rear end
As long as you dont put real sticky tires in the back you should still be able to drive around just fine. If you just have the regular 225's or 235's all you will do is spin the one wheel. Your going to want to upgrade eventually. But like 97camaro said just get a 4th gen rear off of a wrecked camaro take it to a shop have it gone through(fluid change etc.) and stick that in your car. You can get them real cheap.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 10-23-2005, 08:01 PM
Re: Re: Re: my rear end
no... jkjk
what a fag
Old 10-23-2005, 08:32 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Re: Re: my rear end
For the 3.42's u would have to find an M6 LT1 4th gen, other wise u might get stuck with 3.23's or 2.73's.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 10-23-2005, 10:55 PM
Re: my rear end
well call a good junkyard and say LT1 rear and specify which gears, they should be able to do you right on that
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 10-24-2005, 08:31 AM
Link85x Link85x is offline
Re: my rear end
Like 97 said, get an LT1 rear, you won't regret it. One of the best mods that i have ever done. Got better braking due to disk, a new set of gears and new posi (i got really lucky). From a dig the car was magnificent.
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
