Old 10-21-2005, 09:42 PM
IPR IPR is offline
Fuel pump running continuously.
I have a 93 3.0L with a constant running fuel pump with the key in the run position and engine off. I have just started hearing it and was wondering if this was normal as opposed to other makes that shut off when the fuel system is pressurized.
Old 10-22-2005, 10:26 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Fuel pump running continuously.
The pump should shut off when the system is pressurized. You could have a problem with the fuel pressure regulator or the fuel pump relay being stuck. Both will cause this issue.
