Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 10-21-2005, 08:00 PM
posterboy332 posterboy332 is offline
Send a message via AIM to posterboy332
Question my lebaron won't start
i got a 93 lebaron that won't start when i turn the key it is as if i dont have enough battery power but it is not the battery i switched batteries and the same thing happend somebody help my out please
Old 10-23-2005, 02:24 PM
94LebConv3La604 94LebConv3La604 is offline
Is your engine cranking? If so, what does it sound like? Is it making any odd noises? Only thing I can think of right now is if it's not doing anything, it might be a bad contact in the ignition wiring or in the cables to your battery. When you place the key in the start position, does it give a bulb check as usual?
If the engine is cranking, do you hear a loud grinding sound? You probably need a new starter if so.
Are you getting fuel to the engine? If the engine is cranking, leave it crank for a few seconds with the large air hose from your air filter to the intake manifold off. After you crank for a few seconds, smell the opening to the manifold and see if you smell gas. You might have a clogged line and/or fuel filter.
Old 10-26-2005, 01:56 AM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
well, if the engine doesn't crank but makes a buzzing noise then it may be that the engine is siezed or that the starter is junk.
