Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-21-2005, 07:50 PM
Tripseleven Tripseleven is offline
96 Tahoe, Linkage or Sensor Issue?
Hi all. I have a 1996 Tahoe and I just had the parking rod replaced in the tranny (it was bent and not allowing me to shift out of park). The question I have is when I got it back, the indicator light on the dash is off by one position to the right. The transmission shifts right, and the shifter finds all of the gears right, but on the dash it tells me that I am in Reverse when I'm in Park. This means to start the truck, I have to shift to Neutral for it to start, because when I'm in Park, the truck thinks I'm in Reverse. The dealership told me that its a sensor mounted on the tranny, any ideas? Is it something I can fix?
Thanks
Brian
Old 10-22-2005, 06:59 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 96 Tahoe, Linkage or Sensor Issue?
Thanks
Brian
Who did your trans repair?
Sounds like the P/N switch is misadjusted
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-22-2005, 09:39 AM
The local Chevrolet dealer did it. We didn't realize the problem until I went to take the truck home, and by then it was Friday at 6pm and had to have the truck. They said they will fix it but they want it for another full day. I was hoping it was something I could adjust myself. If not, I can take it back but its tough with work and all. Thanks for your time and any help.
Old 10-22-2005, 10:35 AM
GMMerlin's Avatar
I know stuff
Chock the wheels from and back and apply the park brake.
Place the trans in neutral.
Loosen the 2 13mm bolts holding the P/N switch assembly (on the left side of the trans at the shift linkage) and move until the shift indicator displays Neutral
GM WCT
PM Me for details
Old 10-22-2005, 06:47 PM
OK, did what you said and was able to adjust the sensor, but it wouldn't adjust far enough. I could get it between gears on the indicator, but it seems like it needs to go a little further. Is it possible that the sensor is bad and just needs replaced? The linkage seems ok everywhere else. Any ideas are appreciated!
Thanks
