Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-21-2005, 07:39 PM
chriso779 chriso779 is offline
95' Cutlass Cierra Power window problem
On my cutlass the drivers side window will go down but not go up this also happens on the left backseat side as well is there an electical problem? What can i do?
Old 06-06-2006, 10:21 PM
pleptuch pleptuch is offline
Re: 95' Cutlass Cierra Power window problem
My wife has the same car with the same problem on the driver's side window. It goes down fine, but when we try to put it up, it goes part way up and we have to let it sit for a minutes before it will go up anymore. Sometimes it takes several minutes to get it to roll up. If it gets any worse, I'll probably try to find a replacement window motor at a junkyard.
Old 06-16-2006, 09:42 AM
fstilts fstilts is offline
Send a message via MSN to fstilts
Hi
I have the same problem with the drivers side window in my supreme.
Did you ever find out what the problem is. Some one told me its the ground on
the motor but I haven't taken it apart yet.
Thanks
fstilts
Old 07-08-2006, 10:56 AM
Hi fstilts,
I haven't found the problem yet. It almost seems like there's a resistor in there that has to recharge. If the window won't go up, i can wait a few seconds and push the buttom again and it will go up a little bit and then stop. The longer I wait, the more it will go up before stopping. For now, I'm fine with the whole waiting game, but if it gets worse I'll try to fix it.
Pete
Old 07-11-2006, 07:06 PM
94cutsupreme 94cutsupreme is offline
Send a message via AIM to 94cutsupreme
i had the same problem on my 94 supreme on the driver's side window...it would just get stuck at certain points and i would have to pull it up and push it down...i never found out what the problem was but it seems to be common so i'm sure someone around here knows what's wrong
94 Cutlass Supreme-It went bye bye
95 Cutlass Supreme-Done at 250,000+miles!
05 Nissan Sentra-1.8 SE manual-shittier than I thought it would be
Time to consider a new car
Old 07-12-2006, 04:46 PM
mrstg65 mrstg65 is offline
Check those rubber strips on either side of the glass. If they are worn water could get in and cause damage. Beyond that I would try replacing the motor if it gets any worse.
Old 07-13-2006, 03:18 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
i would think maybe the track needs some lubrication on it, but the problem almost sounds like its not that, i had a problem on the passanger window where it just bounced on the way down, and got annoying, but what i did was spray some WD40 on the little plastic strips on both sides of the glass, as well as in the sides of the door where the window rides. it helped me, but im not sure about your problem, maybe it can help
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
