Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 10-21-2005, 08:20 PM
fakehatch fakehatch is offline
EXTREMELY soft brakes
I just got done changing my pads on my 96 civic DX. I accidentaly loosened the bolt on the pssenger side that the brake fluid is attached to and lost a couple ounces of brake fluid and quickly re-attached it.
I pumped the brakes after I was done, 5 minutes, and haven't re-gained brake pressure. I took it around the block and it stops, but it doesn't jerk, which it should. It doesn't feel safe.
Help please....
-Ras
Old 10-22-2005, 08:49 AM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
Re: EXTREMELY soft brakes
u probably put an air in your brake lines, bleed it, and try it again, adn if you can't bleed your brakes....or dont know how...you shouldn't be touching your brakes
Old 10-22-2005, 11:39 PM
Thats what I figured, and yes I do know how to bleed brakes, done it to my motorcycle, just not the civic.
Since I only fucked up my passenger front, is that all I need to bleed?? Or should I do both fronts?
Old 10-23-2005, 12:43 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Just the one you lost fluid in, but it's good to bleed your entire system when you're change your pads/shoes to keep the fluid from breaking down.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-23-2005, 06:25 PM
Banned
actually....u dont have to bleed your brakes after u change just your pads.....it's a myth....i suggest u bleed your whole system....starting w/ RR...LF...LR...RF
