Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-21-2005, 06:02 PM
angela5503 angela5503 is offline
Cause more problems cleaning EGR ?
I want to clean the EGR on my 01 but someone mentioned that all the loosened carbon goes back into your engine. Is that potential for more severe problems. The dealership wanted $192 to clean the EGR system,would they do it the same way?
Old 10-21-2005, 07:24 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Check here EGR Cleaning
It tells you how to do it without all the stuff flushing into the engine.
Old 10-21-2005, 10:07 PM
rodeo02 rodeo02 is offline
Flushing out the EGR plumbing will result in some black dirty intake cleaner dumping into the common chamber, but it wont hurt a thing. You can stuff some rags in thru the throttle bore to sop it up if you want to, but it's not needed. There is no way for the dirty cleaner to get sucked into the combustion chamber as the intake runners are ported up high in the common chamber/plenum. No matter what you do, it's always a nasty black mess in the common chamber due to the normally functioning EGR system. You may get a hard start, some hesitation and a CEL right after an EGR cleaning from the cleaning vapors, but it will go away after a minute or two. 10-20min and a $3 can of intake cleaner is all you need to do a better job than a $200-300 dealer cleaning.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
