Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 10-21-2005, 05:22 PM
jasawno jasawno is offline
1995 Chrysler Concorde Turn Signals
The Turn Signals On My 1995 Concorde Will Not Work, They Make A Buzzing Sound Only. I Replaced The Flasher And Checked All The Bulbs, 4 Way Flashers Will Not Work Either. What Could Be Wrong?
Old 10-22-2005, 04:01 PM
AWP9521 AWP9521 is offline
Re: 1995 Chrysler Concorde Turn Signals
Might be a bad mullti-function switch if you already replaced the flasher, and checked the bulbs. Does anything else not work? I ask because the ignition switch can also cause them and other things to not work.
Old 11-15-2005, 04:31 PM
thank you for your reply, I found the problem it was the small wire on the positive battery cable.
Old 09-21-2006, 11:03 AM
Joust Joust is offline
I have this exact same problem. Mine is intermittent. sometimes it works.
I replaced my ignition switch about a year ago. I've pulled the combination flasher and it is ok. It is simply intermittent.
from teh diagram of tehe multifuntion switch there is a connection that connects ground to teh flasher. I believe that that is intermittent as when it is acting up, i get no indicator lights at all. 4 ways, left, right, dash.
One thing though from teh diagram of the internals of the mutifuntion, that ground conenction appears to be only on when 4ways are on. but if that were true the flasher relay would be on all the time so i think that may be misleading.
can anyone confirm?
Old 06-10-2008, 01:44 PM
Turns out my problem was the same small wire that is supposed to be connected right at the positive battery terminal. it was broken inside the insulation.
