Old 10-21-2005, 12:20 PM
boony boony is offline
Question Changing plugs on 97 escort lx
Hi,
Been years since I changed plugs in a car, looked at my son's escort to pull plugs for a look, (120,000 miles), and couldn't get wires off the plugs, didn't want to force the issue. Is there some trick to getting the wires off the plugs, and what size plug wrench works with these?
Also, what is the proper gapping on these plugs? do they come pregapped?
Thanks.
Old 10-21-2005, 06:28 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
The plugs will probably be pre gapped but check anyway. The gap setting will be on a white tag under the hood. Probably under the hood itself or maybe near the radiator.
To get the plug wires off you can get a special tool from the parts place. I think it's called 'plug wire pliars'. My advice though would be to rip the old ones off and replace them. The plug socket is probably a 5/8ths inch.
Nevada Tumbleweed
Old 10-21-2005, 06:29 PM
While you're at it maybe change the fuel filter too.
Nevada Tumbleweed
Old 10-21-2005, 10:40 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Changing plugs on 97 escort lx
get good quality wires and use that silicone to prevent the pllug wires sticking again later. Also I put a dab of anti sieze on them.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 10-22-2005, 08:15 AM
thanks, I appreciate the help. I'll get those plug pliers anyway, and use them to start at least. I'll for sure be replacing them along with the plugs, will use some anti sieze also.
thanks again to both you guys for your responses.
