Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 10-21-2005, 10:48 AM
raceIT98 raceIT98 is offline
Unhappy 93 civic engine swap??
I'm looking for a new engine for a 93 civic hatchback cx. What can I get for a grand or less? What should I be looking for? This is an unexpected problem but I don't want to get rid of the car. Theres a blown head gasket and I would rather pay the extra couple hundred and get a new motor than have it repaired. I found some information that says a B18C would be a direct bolt in....anyone have anymore info on that motor?
Old 10-21-2005, 01:14 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: 93 civic engine swap??
for less than $1000, start looking into any SOHC. try using the search function. it will yield you alot of results.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-16-2005, 11:38 PM
macknos44 macknos44 is offline
Re: Re: 93 civic engine swap??
bingo i picked up a d16z6 with tranny for $150. then a p28 ecu for about $100 (ebay). wire in the vtec to the ecu and your good to go.
you can use the left over $750 to do a diy rebuild with hi-compression 75.5mm pistons for this kind of budget you can get them for $200. get the block honed and decked for $185 at kms engine development they do excellent work(honda-performance.com). tuner toy rods($225) and a oem gasket kit for a few hundred dollars. this will give you a some more gogo fun
Old 11-27-2005, 01:01 PM
cjcivic cjcivic is offline
for another $1000 u could pick up a b16
