Old 10-21-2005, 10:43 AM
daveh815 daveh815 is offline
replace rear axle seals 97 f150
rear axle seals are leaking. How do i replace them and is it difficult?
Old 10-21-2005, 09:36 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: replace rear axle seals 97 f150
Remove rear end inspection plate and remove spider gear pin and small spider gears and the push in on axel and remove U clips on end of axel.
Remove wheels and brake drum and pull the axel out.
Then you will see the rear axel seals. Pop the old ones out with a pry bar or large screw drive or exc.
Then take a flat seal driver and drive in the new ones.
and put it all back together.
While the axels are out look at the bearing surface on them. If worn out or ruff or cut up you may need a axel saver axel bearing.
And check and/or clean greese off of rear brake shoes and drums.
MT-2500
Old 10-29-2005, 09:24 AM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Re: replace rear axle seals 97 f150
MT-2500
hi. i'm postin here because my dad has a 98 f-150, and his rear axle is making this aanoying niose when criving in the highway and we tried to remove it, but since i'm into the import/sport cars, i have no experience with the f-150, i tried researching, but this is the only one that i could find helpful, but i would like to know if anyone knows of any website with instructions and pictures? any help will be apreciated,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 10-29-2005, 09:43 AM
MT-2500's Avatar
AF - Advisor
http://www.alldata.com/products/diy/index.html
It is a one year online sub from all data that will lead you threw it. And also has all of the other repair info.
Also type in auto zone on a web search they sometimes have some info of it.
MT-2500
