Old 10-21-2005, 11:14 AM
red94fourdoor red94fourdoor is offline
Send a message via AIM to red94fourdoor
Smile Royal Purple products
Has anyone tried any of the royal purple products before? Like the Motor oil, trans fluid, gear oil? power steering fluid. I was thinking about changing to all of the royal purple products.
Need feedback before I spend the $$$
Thanks
No thread hijacking
Old 10-21-2005, 11:38 AM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: Royal Purple products
No i have not tried it but might when i get the 5.7 in the blazer.I think for the price it should be good and all shows on tv use it so i dont know.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 10-21-2005, 11:44 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Personally I would use Mobil 1. Royal Purple is not a true synthetic. I have used there Fuel injector cleaner and their oil. I mean it is a much better choice then conventional oil but I would stick with 5 quarts of Mobil 1 for under $20 any day then spending $5.99 a quart for Royal Purple. Oh and incase you are wondering....... The oil is purple.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 10-21-2005, 12:08 PM
Lol i was wondering if it was,no not really but its nice that its purple
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Not to mention Castrol GTX has all of the same properties of Royal Purple for half the price, easily. Same goes for Havoline organic oils, and Dollartree available Phillips Trop Artic Semi-synthetic blend. All have similar origins, being a super-clean petroleum base. They only differ slightly when it comes to the concentration of certain chemical additives. Royal Purple has a ton of Moly in it. But you can again, bolster up a "cheap" GTX fill with Valvoline Synpower Oil Treatment (As mentioned in the Synthetic thread) or go for broke and pick up a $23 5-quart Jug of Mobil-1 which is completely synthetic for "real" for it is not derived from petroleum stock at all, and similarly treating it with the Valvoline product. Your wallet and truck will thank you for it. (I am oversimplifying many details, but do feel free to ask, it's fun!)
Old 10-21-2005, 12:57 PM
Yeh i dont know i dont want to hijack said thread but im camshaft shopping right now for 5.7 ill be in off topic thread if ya need me.
Old 10-21-2005, 01:14 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Royal Purple products
^^^^Listen to this cat, he sums it up perfectly.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-21-2005, 01:37 PM
Mobil 1 it is, I think I may try the drive clean for higher milage vehicles
Old 10-21-2005, 01:52 PM
wolfox's Avatar
A note on the Drive-Clean products:
They are a combination of synthetic additive packs in an organic oil base. You may be better served by trying a run on a Shell Rotella-T synthetic or organic formulation in 10w-30 (There is no 10w-30 in the synthetic, only 15w-40 as far as I know) for a 5,000 mile run. At the end, drain it when hot, then fill yerself up on the Mobil-1. I say this because the run on Rotella is going to seriously clean up the engine and since it is made for "Mixed fleet" (An HDEO oil) it can safely eat up and suspend waste particles that may bypass your filter during this cleaning phase. Once the engine is cleaned out this way, you'll gain maximum benefits of the fresh Mobil-1 synthetic straight out of the bottle. But your first run on Mobil-1's going to finish doing the cleaning. I would not go more than 7K miles on the first fill up on Mobil-1 so no need to go for the "Extended Performance" stuff juuuuuust yet. Then after that, refill with a 5 quart Extended Performance badged Mobil-1 jug and drive to your heart's content. The Mobil-1 will then maintain your engine's cleanliness and smooth operation when changed at 10-12K mile intervals with a spin-on oil filter replacement every 6-7K miles in between complete changes. Good luck! Oh, and please recycle you waste oil products as much as you can if you're a do-it-yourselfer. Ciao!
Old 10-21-2005, 01:58 PM
BlazerLT's Avatar
AF -Advisor
Just go to Mobil 1 synthetic bud, far better results.
