Old 10-21-2005, 09:48 AM
ucutmup ucutmup is offline
A little more help please with Door Panel
Okay, I've gotten off the triangle piece and have removed the two screws in the handle and have disconnected the electrical from the switches on the door.... but I believe the trim piece around the door handle may need to be removed but it doesn't seem to budge...Is there any other screws because I don't see any.......
I also took out the reflector and don't see anything behind it..I also removed the carpeted piece above the handle and there are no screws there either...
Thanks again all,
Sherry
Old 10-21-2005, 10:25 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: A little more help please with Door Panel
There is a screw at the bottom under the little tray thingy. there are 3 screws total, one behind the arm rest, one where the windows switch connections are, and the one at the bottom of that tray.
let me see if I can get a pic for you.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-22-2005, 01:53 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
the trim around the door handle unsnaps also, it is just tough to get loose. and i am pretty sure that the 3rd screw is behind the little lock indicator on the door. then after that is all loose, lift up on the door and it will slide up and then release, and thats it.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 10-22-2005, 01:58 PM
if there are any local car stereo shops around i would stop by there and they should be able to point you in the right direction. i help customers all the time when they are trying to do it theirselves.
