Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-21-2005, 09:48 AM
XZIllR8 XZIllR8 is offline
Question Squeeling Coming From Wheel
I have a 1998 Nissan Sentra. For the last few days, I have been hearing a high-pitched squeeling noise (that sounds like metal against metal) that sounds like it's coming from the front passenger wheel. It's only been happening intermittently (not constant) while I'm driving and not necessarily while I'm braking.
Don't the Sentra brake pads have a spring on them so the brake pad is only depressed when I'm actually using the brakes? Since the noise is there whether I'm braking or not, that's what makes me wonder if it's something other than the brakes. Am I wrong? What could be causing this noise?
Any help would be great. Thanks!
Old 10-23-2005, 02:01 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
I would still guess that it's your brakes. My sound was exactly like yours and it turned out to be the brakes.
Old 10-23-2005, 10:03 PM
willy_g77 willy_g77 is offline
the alternator belt will give off a bad squeal if its not adjusted right or if its worn out. its close to the passenger front wheel also.
Old 10-24-2005, 03:33 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: Squeeling Coming From Wheel
id say brakes. i had that problem till i oilled the rotors to go buy new pads. i needed new rotors as well so it diddnt matter.(kno im not suppost to do that)
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 10-24-2005, 10:49 PM
PWRDbyUNCLEbens's Avatar
PWRDbyUNCLEbens PWRDbyUNCLEbens is offline
I have the EXACT same problem on my 92' se-r, and it's more prominent when I turn my wheel to the left, and it stops for a bit whenever I tap my brakes.
A technician at work told me to get this adhesive stuff from the auto parts store, and put on the back of the pad to keep it in place. I just changed my rotors up front, and I know for a fact none of my cotter pins a rubbing. I'm confident this will work (although I haven't done it yet)
1992 Sentra SE-R: Bluebird SR20DET @ 10psi, 3" exhaust, FMIC, Poly-Urethane Motor Mounts, Centerforce (slipping) Clutch, Tein SS coilovers, FSTB, RSTB, 205/50/15 Hankook RS2's
Old 10-26-2005, 02:11 AM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
puting the anti-squeal will fix it, I had that problem and when I replaced the pads I used the anti-squeal and it fixed it.
