| Off-Topic Talk about anything other than cars. |
hey, im new and i just became a member. I was wondering if anyone knows where i can find a cheap 90-94 eclipse tranny for my car. Its the only thing from stopping me from driving my car and im really starting to get mad about it, if anyone can help i'd really appreciate it thanks
Dom |
eBay and local junk yards. You could check the classifieds at www.dsmtuners.com.
Re: i need a tranny
thanks ill try it
Re: i need a tranny
could you tell me something, there is a turbo tranny from a 1991 talo tsi fwd with 50k on it. would it work for my car?
Re: i need a tranny
You have an Eclipse correct? An Eagle Talon or Plymouth Laser transmission will work. Not sure if turbo tranny's will work on a non turbo, but if your car is a turbo, then that one will work. Also AWD and FWD tranny's arent interchangable.
Re: i need a tranny
Unfortunetly my PC does not have the technology to figure out what kind of eclipse you have. I don't think many members on this forum are about to play guessing games either. How do you expect anyone to give you a direct answer knowing you have some random '90-'94 eclipse?
BTW, you gotta get one of those thing's that has stuff on it, this one place has it
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister Last edited by macder; 10-22-2005 at 06:58 AM. |
Re: i need a tranny
The Turbo and Non-turbo trannys are not interchangeable unless you want to change the starter and some other things. Where the starters bolts up there is like a 1/4" to a 1/2" difference in the bolt pattern and the dust sheild won't connect right on.
Try putting your car in your sig or else you'll keep catching shit for it. Good Luck |
1g manual FWD trannsmission -$350
2G flex plate - $25 2G oil filter assembly -$50 2G intake manifold - $75 2G complete head - $100 2G pistons -$100 2G rods -$50 2G crank -$75 2G oil pan - $10 2G trottle body - email me Let me know if your interested... Im rebuilding a gsx 95 eclipse...if you have questions |
