Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-21-2005, 04:30 AM
sixpac sixpac is offline
front end noise
frist of all let me tell you what i fixed so we can rule out these problems
wheel bearings.
ball joints.
tie rod ends.
pitman arm.
stearing link arm.
let's just say i rebuilt the whole front end,which is starting to cost me an arm and a leg.
the problem i'm having now is when i'm driving i hear a squeaking noise coming from somewhere on the passanger side it sounds like somebody is sitting on a rocking chair rocking back and forth.also when i push up and down on that side thats when i can really hear it.but i have no ideal where the noise is comming from.would a bad shock cause this problem?
Old 10-21-2005, 04:33 PM
drdd's Avatar
drdd drdd is offline
Re: front end noise
grease all 11 grease-fittings under your truck. that should do the trick. Should cost about $10 for the grease gun and $4 for the grease. If it doesn't solve the problem, no big deal. It needed done anyway and didn't cost much.
This fixed my creaks when at first I thought it was the shocks.
wheel bearings.
ball joints.
tie rod ends.
pitman arm.
stearing link arm.
Old 11-10-2005, 11:31 AM
taylorman taylorman is offline
Re: front end noise
After all that work are you sure that your metal disk brake guard isn't rubbing on the disk. That would cause the squeaking.
Old 11-12-2005, 06:21 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Take a look at your sway bar links, and the sway bar mount bushings. When they get old and dry, they squeak.
