Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 10-21-2005, 02:31 AM
newcarbyr newcarbyr is offline
2006 civic engine compression ratio...
The new 2006 Civic's have a 140 hp engine that has a 10.5:1 compression ratio. Is it possible to run this engine on regular unleaded (87 octane) or will it need to run on supreme to keep it from pinging?
Old 10-21-2005, 10:10 AM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: 2006 civic engine compression ratio...
87 recommended as usual.
03.IS300.MT.LSD. 'Supra in Training'
Old 10-21-2005, 03:10 PM
Thanks, BrodyP. I guess my real question is how can an engine with 10.5:1 compression run on 87 octane without pinging? The Corolla XRS is 11:1 and it has to run on Supreme. Does Honda have to program the computer to compensate for it? And if so, how much more power would be gained if the computer were programmed for Supreme?
Old 10-23-2005, 08:46 AM
BrodyP's Avatar
AF -Advisor
Here is some reading on the subject if that hepls out.
LINK
Old 10-23-2005, 09:35 PM
gmcuajo gmcuajo is offline
Re: Re: 2006 civic engine compression ratio...
If the computer is programmed for regular (87 octane) it will work with this minimum. If you use Supreme the computer is capable to adjust the air/fuel ratio for this octane rating, but this can have another consequences...
Old 10-25-2005, 04:57 PM
LesGrandsPieds LesGrandsPieds is offline
dude, my dad tells me that no car with a compression ratio over 10 should be run anything but premium.
