Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-21-2005, 01:16 AM
Picquerist Picquerist is offline
Send a message via AIM to Picquerist
94 camry dx 3S-GTE swap
saying i get 3SGTE with ecu wires all that goodness
how much work is really involved with this?
i know knew front axles..
will this slide into place?
Old 10-21-2005, 01:20 AM
Re: 94 camry dx 3S-GTE swap
http://cgi.ebay.com/ebaymotors/JDM-C...08303233QQrdZ1
any suggestions?
Old 10-21-2005, 09:29 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Old engine & transmission comes out. Along with the axles & the entire TCCU.
New TCCU goes in. Buy an E-153 manual transmission + differential + aftermarket clutch & throw-out bearing + axles off either a 92-93 Camry/ES, or the E-153 out of a 5-speed v6 Solara.
Along with the clutch pedal + mounting, clutch lines & hydraulic system.
Clutch stuff get's installed.
Transmission & diff mate together & get installed. New axles go in.
3s-gte goes in.
Fuel pump is upgraded.
Custom exhaust pipe welded up to get from the turbine exit to the cat-convertor.
Custom intercooler pipes, intercooler & charge pipes done.
It's really not a good idea overall.
You can do a v6 swap much cheaper & have the same power, with more power potential.
You can also just turbocharge a 3s-fe, or 5s-fe in the first place using the 3s-gte, or custom manifold. They only hold 200-230bhp safely.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 10-22-2005, 05:37 PM
i'm gonna keep the tranny in there it will match up with the 3sgte
i'll i need is a new clutch and some very minor work with mounts
i headed over to toyotanation.com
thank you for your response though
Old 10-22-2005, 09:08 PM
Toysrme's Avatar
AF - Advisor
Cool
The M/T tranny you have isn't going to be up to a stock 3s-gte over the long run, or a modified 3s-gte over any amoutn of time.
Good luck, ya I saw the post on TN. Same info.
