Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 10-20-2005, 10:55 PM
Justinjj727 Justinjj727 is offline
Send a message via AIM to Justinjj727 Send a message via Yahoo to Justinjj727
Unhappy bad ball joints pics. heh
well my bird is clunking, squeekin, and squeelin everytime i turn the wheel and go over bumps. Well decided to take pics of the damages finally and post them. I'll be replacing all of the ball joints with moog parts and sway bar links as well. then eventually do the suspension!
BLEH!
Old 10-21-2005, 04:36 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: bad ball joints pics. heh
By the looks of them, do it quick or don't drive the car!
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 10-21-2005, 07:49 PM
can't really do them asap. but i will do them as soon as i can get to them. Its my only means of transportation because 1 car is down for a major build up.
I will need a ball joint seperator for sure for the bottom and tops right? Also for the sway bar links should just pop out as soon as they are loosened right? Any pointers? And whats the best way to go about this???
Thanks
Old 10-22-2005, 12:22 AM
Spray everything with PB Blaster, WD40, or the like the day before. Never replaced the lower bj so can't advise there. The swar bar links are easy if you can keep the ball from spinning inside the link as you try to take the nuts off. Once the nuts are off, a baby sledge (3lb. hammer) should do the trick or even a pickle fork. As far as the upper a-arms, jack up and support the front of the car, remove the tire, remove the through bolt, and use the same hammer or pickle fork.
Old 10-22-2005, 06:24 PM
Thanks alot man. Help greatly appreciated!
Old 10-22-2005, 11:17 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Re: bad ball joints pics. heh
Just replace the entire lower & upper control arm assemblies.
You will want an 18mm racheting wrench.
Check with your local parts supplier or you can order
the entire lower & upper control arm and ball joint assembly from Rock Auto.
Here is a 5% discount code for Rock Auto
that is good until December 6, 2005
- 309419231367
Old 10-23-2005, 12:57 AM
alright thanks for the help. guess i'll just replace the assmbly. When I have a chance at work I get to look up a little bit of parts.didnt get to the lower assembly to take a look at them.
Thanks for the site I'll keep it in mind. I work at Oreilly so i get what the store pays for it +tax.
Thanks buddy!
Old 10-24-2005, 08:15 PM
finally got them both changed out. wasnt too bad. just used vise grips to hold the bars also If you clunking over bumps this is also a very possible fix. Mine clunked all the time. It still squeekes but i'll get to that. heres a pick. Moog Vs stocker.
Old 10-24-2005, 08:21 PM
BTW I still gotta do upper and lower ball joint but i did already plan on the above suggested and do the who assembly's. But for the bottom i will have to compress the coil springs for the struts so I'll just gather upper and lower assembly's over time along with some new struts. Do it all at once.
Old 10-25-2005, 09:12 PM
If your ball joints, upper or lower, give out, hold on for the ride of your life if your doing highway speeds.
Old 10-26-2005, 11:08 PM
i'm gonna have too. Katrina took all my money and I'm working full time to make money to fix these things. Right now more money is comming out of the account then whats going in and thats barely making it by. before too long i wont be able to get by. Why are fords notorious for this crap..
