Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-20-2005, 09:55 PM
k_dawg k_dawg is offline
Blinker not working
I have a problem, whenever it gets really cold outside my left blinker does not work. I will push the blinker on and after about a minute it might work. How do I fix this problem.
Old 10-21-2005, 04:02 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Sounds like your thermal flasher. Turnsignals' blinking is controlled by a wire the heats up and cools off, if its an old piece and it's too cold, it will take time to warm up. Replace the thermal flasher and you should be good.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-24-2005, 05:34 PM
Where is the thermal flasher in the unit? How do you get to it? DOes it have two prongs or three? How do you replace it?
Old 10-24-2005, 06:52 PM
NA is Best!
Re: Blinker not working
Find your interior fuse block on the lower left side of the steering column. Look for the small black box in the corner of the fuse block. Pop it out and bring it to your local parts dealer and get a new one exactly like it.
Old 10-24-2005, 07:33 PM
Do you have to take your dash off or is it right below the steering wheel?
Old 10-25-2005, 04:42 PM
NA is Best!
Ok, at the lower left hand side of your dash, there should be a little door(if yours still has it) if not, just an opening. Look up it and you'll see the fuse block and look along the edge and you'll see the little black box.
