Old 10-20-2005, 09:45 PM
RoccoSR RoccoSR is offline
Angry ABS light in F350
My 1996 F350 has a ABS light that stays on all the time. I'd like to know if there is any info about this or anyone that has had a similar problem.
Thanks
Old 01-30-2006, 07:31 PM
smitty's735i smitty's735i is offline
Re: ABS light in F350
hi, i have an99 f150 with the same problem. Unfortunately i don't know of any solution, but still searching.
Old 01-30-2006, 08:11 PM
bricotrak bricotrak is offline
I had a 1993 e-150 with same problem, but the red brake light would also come on when brakes were applied, and the brakes would drag. It turned out that the RABS valve was bad. (located under vehicle about half way back with brake lines attached) I had dealer unplug ABS module (located on firewall somewhere) It took care of the brakes dragging but now rear brakes are no longer ABS. Hope this helps
Old 01-30-2006, 09:54 PM
(quote=smitty's735i) Thanks for the info. I'll try that.
Old 02-06-2006, 03:31 AM
msp msp is offline
Exclamation Re: ABS light in F350
I do believe I have the answer for you. Check your vehicle speed sensor. It should be located above the rear differential. Good luck. Michael
Old 02-06-2006, 03:52 AM
msp msp is offline
Or try...http://72.14.207.104/search?q=cache:...s&ct=clnk&cd=4
Old 04-05-2006, 12:48 PM
steve longo steve longo is offline
take off one wheel at a time and look and see if brake dust and drum/rotor metal is bridging the gap on the magnetic pick up and reluctor. If you spray some brake cleaner or have a compressor ,blow all of the debris out. Don't forget to wear a mask and goggles. the metal dust bridging the gap will light up the abs light like it did on mine. Are you hard on brakes?
Old 04-05-2006, 07:36 PM
Believer45 Believer45 is offline
My 95 F250 did the same thing. I checked all the fuses, speed sensor, vacuum pump, brake fluid level sensor, wiring, connections and everything else I could think of. Finally got frustrated and pulled the fuses out to inspect (I had checked them with a test light at both contacts while they were in place) and found one of the tabs broken off coming out of the bottom of the fuse. Replaced fuse and the ABS light that had been on for a year went out, been fine since.
One of those really strange things that come up once in a while.
Dave / Believer45
'95 F250 power stroke 5 spd 4x2, extended cab, long bed, 3:55 rears, open air filter, 285/75x16 Cooper ATR tires, LUK single mass flywheel conversion, Putco master boss running boards, aluminum cap on bed, custom rear bumper (@450 lbs), scale weight full of fuel, me in it (285#) - steer 3420 lbs drive 3160 lbs gvw 6580 lbs, 280,000 miles as of Feb '09
Also 1996 Chevy Cavalier 2.2 auto 4 door LS, 95,000 miles.
