Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 10-20-2005, 07:33 PM
shargirl shargirl is offline
camshaft sensor
I am getting ready to have my camshaft sensor replaced and I was wondering if anyone had any good pointers or advice.I had my comp read by a friend and that was all that came up. I hope that is all that is wrong.It is a 1999 with 93,000. Only other major thing was my wheel bearings that were replaced this past summer. What else should I look out for? Thank you!
Old 10-20-2005, 09:17 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: camshaft sensor
if you have not had your timing and serpentine belts replaced (typicly done 60-75k miles) I would have that done for preventative maintenance.
Old 10-22-2005, 05:23 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Re: camshaft sensor
As zx says, change your timing belt. The zx2 is an interference motor. This means that if the timing belt breaks the valves interfere with the pistons. If a valve goes through a piston you will be looking at a new motor. Two objects cannot occupy the same space at the same time. The newer belts are made out of kevlar (the same stuff they make bullet proof vests out of). They are typlically good for 100,000 miles.
Old 11-16-2005, 09:43 PM
.ks .ks is offline
Re: camshaft sensor
Originally Posted by shargirl
I am getting ready to have my camshaft sensor replaced ...
My comp says bad sensor too. :-( What were your symptoms?
thanks,
Kevin
Old 11-17-2005, 03:43 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Re: Re: camshaft sensor
wrong
zetecs are non-interference
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-17-2005, 06:03 PM
Banned
Re: camshaft sensor
yes it is a NON-interferance so the motor just shuts off
