Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 10-20-2005, 05:46 PM
TurboH22civ TurboH22civ is offline
Help Meeee!!
Ok, i have a quick question for you, i have a 94' civic coupe with a jdm 94' h22 swap. It is setup with a T25 garret ball bearing turbo, 2.5in intercooler piping and a precision turbo intercooler. i am currently running 11 psi. I have a h23 tranny with an ACT 6 puck clutch and ACT chromoly flywheel, i dynoed this weekend and only made 197hp and 225tq at the wheels. i know this motor is rated at 200 crank hp from the factory and the turbo should have added at least 88hp. shouldnt i at least be making 255+hp at the wheels? also the car goes really rich when VTEC engages. Any answers or help would be greatly appreciated
Old 10-20-2005, 06:24 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Help Meeee!!
boost leak ? and some engines need a once-over every-so-often to keep them in tip-top condition an running well. you said it was 200bhp (ATC) from the factory, dont forget you usually have a 10-15% power loss through trasmission an drivetrain resistance/friction. so you should be gettin 240-260bhp (ATW) as a guess. but otherswise i dont know.
Seatbelts Saved My Life
Old 10-20-2005, 08:15 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Help Meeee!!
Definently check for a boost leak, and check to see if the injectors popped out. If all that is fine, then get yourself a new turbo. My friend had this exact same thing happen to him. That turbo will give you far more torque than hp, it's too small.
Old 10-20-2005, 09:59 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Help Meeee!!
what kind of engine management do you have ?
Team Lonely Drivers
Old 10-21-2005, 04:29 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Help Meeee!!
your boost gauge is reading? your compression results are? your engine management is?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-21-2005, 11:28 AM
Re: Help Meeee!!
my engine is managed by the V-AFC 2, my compression is good and my boost guage reads 10-11psi, im pretty sure im not leaking boost and my injectors are fine, i was considering that the turbo may be to small.
Old 10-21-2005, 12:46 PM
AF - Advisor
Re: Help Meeee!!
dont waste your time and money on a t25. ditch the vafc.
Old 10-21-2005, 10:06 PM
Re: Help Meeee!!
so i should get a new turbo and an engine management?
Old 10-21-2005, 10:41 PM
CivicSpoon's Avatar
There is no Spoon
Re: Help Meeee!!
Yes.
Old 10-22-2005, 09:32 AM
Re: Help Meeee!!
like what size turbo and what kiind of engine managment
Old 10-22-2005, 10:48 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Help Meeee!!
Uberdata or chrome and for the turbo.....use something like a t3/t04 .57 trim or anything that's bigger than a little t25! If you want ball bearing an good spool up, get a GT28rs.....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
