| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Power window prob on 1995 3.8
Ok, here is what I have. My driver's side window is not working. Running some voltage checks I actually have power to the switch and the motor works fine (can be jumpered to be made to work) as does the mechanism. It indeed acts as if there is a relay stuck. There is also an automatic down on the switch so I assume there is a module of some sort that controls the window circuit. Hays manual is useless. Anyone know where this relay or module might be located?
Re: Power window prob on 1995 3.8
Did you follow the wiring from the switch to the motor making sure all the connections are good? A wiring diagram may help in identifying and locating the components in the circuit.
The wiring diagram shows it in the circuit but not the physical location on the relay module. The power to the switch is good and the motor and connections to it are good, problem is the wires to the window switch ties into a harness that has fifty gazillion wires and head off to parts unknown.
Re: Re: Power window prob on 1995 3.8
Ok, with the help of a couple of sources I found the module. It is actually mounted on the inside of the driver's side door panel near the bottom under the armrest. Mine had simply come unplugged due to interfernce with the window regulator and I didn't notice it on the panel itself. |
