| Let's get Technical! Discussion for hardcore in-depth motor heads! |
this is wierd....
my car will puff some white smoke whenever i get on the gas...
did a cylinder compression test... 210 in all 4 cylinders... so rings are great... does not leak any oil..... at alll... oil is old needs changing bad and my car does'nt ever heat up... always cool where its supposed to be... i do not know what is wrong... i have yet to change the oil but i dont see how that could cause white smoke..? |
Re: this is wierd....
is it turbo ? white smoke under acceleration on turbo cars often indicated that the turbo's burning oil.
Seatbelts Saved My Life
When it happened to me it was a blown head gasket. If it is the early cold morning the exhaust will be evaporating the condensation inside. If it is none of these two things, I am not sure.
not turbo..
stock jdm b16a 92 just have intake exhaust... has old stock cat convertor and stock exhaust piping headgasket blown it would overheat rite? my shit runs cool man oil is bout 8 months old and test 210 in all 4 cylinders so i know the block is sealed up nice |
what color is your coolant ?
Yeah it could be a real small crack in the head gasket, but shit, change your damn oil. Hondas need oil changes frequently. The b-series engine is a high reving, high compression motor. You should be changing the oil every 3,000 miles.
im changing oil tommorow and plugs..
coolant is green.... fresh |
only puffs white smoke at low low rpms.... when i rail on it nothing comes out
It won't smoke when you stomp on it.....think about that!
If you run it up to higher rpm's and then let it slowly rev itself down, under its own power, you'll smoke liek a Mofo! Do you know why? Its because that gasket has a vaccuum on it and therefore the coolant is sucked into the cylinder and burned....white smoke! When you stomp on it, there is no vaccuum so the heavy coolant stays where it is.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
but if headgasket is blown... wouldn't my car heat up?
and when i let it downrev on its own ... it dont smoke either.. |
evaporation maybe.
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
idk, but so far i'm stickin w/ the hg.....
just cause its got good compression doesent mean its not oil.. lets face it its a 92, could be valve stem seals they are basicaly rubber and they just get old and hard and stop working properly, plus the piston rings have three rings one is an oil ring all these could play a part in oil smoke
j |
sounds like the head gasket to me, there is like 3-4 differnt places it could crack and cause several diffent problems, between the cylinder and oil line, cylinder and coolant line, cylinder to cylinder, cylinder to outside there is alot of possibiltys
i would just take the head off and rebuild it. it doesnt cost much for head gasket, valve stem seals, and everything else you would need
