Old 10-20-2005, 03:18 PM
misfitt006 misfitt006 is offline
Send a message via Yahoo to misfitt006
Tires or milage?
Hey everyone just wanted to get ya'lls thoughts on this. I put on my K&N FIPK and went from 265's to 285's in the same day and have almost run through my first tank of gas. As it stands now it looks like I'm going to get between 60-80 miles less off this tank than I have always gotten before the mods. Now in YHO is the difference bad milage from the bigger tires? Or am I just covering more distance with the bigger tires than my odometer is reading because I haven't gotten it recalibrated for the bigger tires yet. Or is it most likely a combination of the 2? I haven't done the exhaust yet because I'm still trying to decide what I want.....like I read in another post I wish they would let us try them out and return the ones we didn't want hahaha
Old 10-20-2005, 03:55 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i would guess that it is the tires size difference that is causing this. my spedometer is off by 5 at 65 and off by 2 or 3 at 30. and in a whole tank it throws it off by 70-90 miles on a tank.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 10-20-2005, 05:21 PM
so you don't think i'm actually getting worse milage then? it's just the fact that my odometer says i've gone 300 miles when in fact i've gone closer to 380?
Old 10-20-2005, 05:25 PM
98vert6spd 98vert6spd is offline
Re: Tires or milage?
I HAVE THE 285 75 16S AND MY MILAGE IS OFF BY 6.5%
drive a set milage and record distance
then drive in a nother car with stock tires and record distance
then compare
Old 10-20-2005, 08:03 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Go to the discount tire site and they compare tire sizes and you can see the difference in distance travelled. Then do the math.
I bet you have been gassing it a "BIT" more with the new intake Right?????
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 10-20-2005, 09:11 PM
Re: Re: Tires or milage?
I've been actually pretty proud of myself. I've been a "good boy"......for the most part. But I have to admit that I just love the new sound of the engine when I open her up a little lol.
Old 10-23-2005, 02:22 PM
LongIslander26's Avatar
LongIslander26 LongIslander26 is offline
You need to pay the dealer a visit and have them program your new tire size into the PCM with the GM Tech 2 scanner, and then your mileage reading and speedo should be accurate, since then the truck will know what size tire it's dealing with.
ASE Certified Automotive Technician
ASE Certified Service Consultant
ASE Certified Parts Specialist
Employed at an Independent Shop
Vehicles:
2005 Silverado LS Crewcab 4X4
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-23-2005, 02:30 PM
what should a stealer charge to reprogram the speedo?? since it probably takes all of 2 minutes or so. i am sure they charge like 200 or so. you might as well go buy a hypertech or get a nelson tune and have him set it.
Old 10-23-2005, 02:45 PM
When I worked at a dealership, if you bought the truck from us, we'd do it for free. Otherwise it's usually around 50 bucks or so.
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-23-2005, 03:59 PM
draboo's Avatar
draboo draboo is offline
I just went from 245`s to 265`s on my 99 Silverdildo and my mileage seemed to go down by 1-2 mpgs.
My speedometer was exactly 5 mph off at 65 mph,as someone previously stated. Now its right on with my GPS.
Seems to me like you should get better mileage with higher profile tires,but since your speedometer is always off,unless you reprogram the puter for each different set of tires,its hard to make that determination.
It also takes more work to get and keep taller tires rolling.
Old 10-24-2005, 12:03 PM
The dealer here said it would take 30-45 min and would cost about $40. I don't know if I'll go and get it done or just wait until I get my Nelson in feb.....
