Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 10-20-2005, 02:42 PM
j hunter j hunter is offline
Angry my heat just stopped working
when i started my 1990 celica this morning my heat was no longer functioning...not at all. since im new to this forum i was wondering if some one could help me out.. its starting to get cold here in new york!
Old 10-20-2005, 10:55 PM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
is there any coolant leaking? that could mean a hose is messed up but i figure that you would have noticed something like that it would probably be a pretty big puddle
Old 10-21-2005, 10:05 PM
SigmaProjects's Avatar
SigmaProjects SigmaProjects is offline
Send a message via AIM to SigmaProjects
Re: my heat just stopped working
drive the car around, when it just sits in idle with the heater on it may not do much, just drive with the heater on it will warm up real fast.
RAs, the last of the RWD Celicas... http://truestreets.com/ now out of BETA
Old 10-25-2005, 08:54 PM
growe58 growe58 is offline
Re: Re: my heat just stopped working
Jumping in a little late here, sorry.
Is the temperature gauge registering normally? If the thermostat is stuck open the car won't warm up and won't deliver any heat.
Make sure your coolant level is correct. If it is too low, there won't be enough to circulate through the heater (not to mention may cause engine damage). You may have lost coolant over a long period through a small leak that was not noticeable. Or you may be sending it out the tailpipe via a blown head gasket or cracked head (I hope not).
An air bubble in the system could cause the same problem, but I don't think that 90 Celica's were normally subject to that.
Does the knob for the heat control feel like it's actually working, e.g does it resist turning? I don't recall, but I think it's cable operated to the heater valve, if the cable broke, you wouldn't be opening the valve.
Finally, how cold was it where you live? If you're running straight water and it froze up, it would be unable to circulate to the heater.
Good luck
Old 10-30-2005, 11:16 AM
jimbobillybob jimbobillybob is offline
I'm not sure if the 5th gen is the same but the 4th has this problem with the automatic climate control.
http://www.automotiveforums.com/vbul...d.php?t=159202
