Old 05-21-2002, 11:55 PM
hatchman hatchman is offline
how can i tell i my new engine is a REAL JDM TYPE R
hey guys i just got a 1.8 litre type r...how can i tell if it is really a type r. almost every thing says p73 but i want to know what should it say on the block...b18c...b18cr or what? Again, it is supposed to be a jdm type r engine. and i have two days to inspect it. if you guys can think of anything else that i can check please post it. it does has the type r intake manifold and lsd tranny.
thanks
hatchman
Old 05-22-2002, 12:12 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Whats the exact code and engine number stamped into the block?
Old 05-22-2002, 12:40 AM
b18c....i read on a websight that jdm motors have no number after the letters (like b18c5)....is this true?
Old 05-22-2002, 01:01 AM
Moppie's Avatar
Master Connector
Its generaly true.
but how about answering my first question. I can help you if your dont help me.
Old 05-22-2002, 01:10 AM
i dont have the number in front of me it is at my shop....i can post it tomarrow. is that a serial number or a standard number that is on all of the same type of engines....and is the number your asking about under the b18c stamp?
Old 05-22-2002, 01:13 AM
Moppie's Avatar
Master Connector
Thats it.
Directly under under the B18c stamp on the same flat surface should be the engine number.
I believe I can find the numbers that corospond to the ITR engines.
Other things to look for of course are a red valve cover, and a quite differnt single runner inlet manifold. (its the easiest way to spot a fake)
Old 05-22-2002, 01:21 AM
what do i look for on the single runner inlet manifold???
Old 05-22-2002, 01:32 AM
Moppie's Avatar
Master Connector
You look for a single runner inlet manifold!
The standard VTi-R teg in Japan uses the same inlet manifold as the GSR in the states (funny that, thier the same car). But the Type R, like the Type R in the US uses a differnt inlet.
If your engine has the standard dual runner inlet manifold then its clearly not an ITR engine.
But if it has a differnt manifold, with only single runners going to each port then its more than likely from an ITR. (although they are sometimes put on lesser engines).
Old 05-22-2002, 09:55 AM
the number under the b18c is 2002802
Old 05-28-2002, 11:19 PM
tenzoracerevovii tenzoracerevovii is offline
or if you're building it.....look at the #'s on the pistons......if you're able to...... the different codes can tell you....unless they just threw in some ITR pistons .....
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Old 05-29-2002, 12:54 AM
Moppie's Avatar
Master Connector
Well the Tech at Honda is pretty certain thats a real B18c from an ITR.
Old 05-30-2002, 02:50 AM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
Also, JDM ITR motors differ from USDM versions in teh fact that their valve cover has a 'H' on it while the USDM version does not.
And for the reasons we stated on JDMCivic.com
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 05-31-2002, 12:30 AM
also the dohc vtec "label" i guess......it's different from the usdm ones.....like.....the "dohc" is bigger than "vtec"....or the other way around......but you can't really trust valve covers now can you?.....too many fakers out there......
-me
-obiewancoyote
Old 06-01-2002, 07:38 AM
Mugen_R's Avatar
Mugen_R Mugen_R is offline
Send a message via AIM to Mugen_R
Re: how can i tell i my new engine is a REAL JDM TYPE R
thanks
hatchman
how much did it cost you???
The engine and tranny?
Old 06-04-2002, 09:06 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
there's a very simple answer to this very simple question of... "Is my JDM ITR motor a real ITR motor?"
the block will be stamped with "B18CR" instead of "B18C" (Japanese VTi-R motor) or "B18C5" (USDM ITR motor)
How can I read engine codes? skite Storm 2 01-18-2006 04:55 PM
How to tell the diff. from JDM type S H22? SBallerk2 Prelude 13 12-13-2004 11:23 PM
