Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-20-2005, 01:39 PM
locdogg555 locdogg555 is offline
Problems with Tiptronic after installing new battery
I have '99 Passat V6 GLS and i had to change battery...after that check engine light went on and Tiptronic Transmission start acting wierd...when shifting between 1st and 2nd there is a pause( as if shift into neutral ) then hard re-engagement all of a sudden. Before battery change, everything was OK! Thanks
Old 10-23-2005, 07:12 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
you need to re-adapt the throttle body. Try slowly depressing and releasing the gas pedal with car of key on. IF that doesnt work you will need the vw dealer to do it with the scan tool.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-03-2005, 11:21 PM
allmotorb16a allmotorb16a is offline
Re: Problems with Tiptronic after installing new battery
readapt throttle control,and reset kickdown posiiton with a factory scan tool 1551/5051/5052 amd its butter from there..
