Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-20-2005, 08:31 AM
mt54 mt54 is offline
ABS Wheel Sensor
ABS light is On, I have no scanner, and my experience has been usually means a bad speed sensor.
Looking at the wheel sensors from the control box with an ohmmeter is there a way to tell which sensor is bad ?
One front sensor reads wide open, the other reads with a high resistance short. What would the normal reading be ?
I have taken the readings from the control box and the last connection to the sensor, this should eliminate the wiring between. I also have removed the sensors and cleaned them, the readings remained consistent.
Any help on what the reading should be ??
Thanks
Mike
Old 10-20-2005, 09:12 AM
maxwedge maxwedge is offline
A990 racer
Re: ABS Wheel Sensor
1450-1800 ohms is the approximate range.
Old 10-20-2005, 02:48 PM
thanks, I'll take a look at it agian.
Mike
