Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-20-2005, 06:11 AM
rpederson rpederson is offline
3.5 L Water Pump
I hate to sound stupid, but, I have a cooling problem with my 97 intrepid 3.5L I have replaced the thermostat and the radiator. The car still overheats. I am almost sure that the water pump is the problem. However, where is the water pump? Is it belt or gear driven?
Old 10-20-2005, 06:34 AM
Jr030303 Jr030303 is offline
Re: 3.5 L Water Pump
It is belt driven and can be found behind the front engine cover. It is driven by the timing belt.
Old 10-20-2005, 10:59 AM
Thanks!
Old 12-17-2005, 02:50 PM
kbp0427 kbp0427 is offline
Don't foget to bleed the water from the goose neck. I had the same problem and it was that I didn't bleed the water.
Old 05-20-2007, 11:06 PM
K winkler K winkler is offline
Smile Re: 3.5 L Water Pump
It is belt driven off the back of your timing belt. The water pump is located behid your timing plate cover. To get this off you will have to remove your harmonic balancer and maybe even your radiatior. 3 little bolts hold it in there. I've been there, done that.
Old 05-21-2007, 05:19 PM
wafrederick wafrederick is offline
Banned
To get the pulley off,use a special 3 jaw puller and you can probally borrow or rent one from the dealer.There are no holes for a harmonic balancer puller.Put in a new timing belt at the same time,you do not need to do it a second time.
