Old 10-20-2005, 03:44 AM
Julioluko Julioluko is offline
Can i put a 6Bolt 92 n/t in my turbo and change the cams?
Hey guys i was just wondering, i need a new engine, and i was just thinking: If i throw a 92nt motor in my 92 blown turbo engines place and just switch around the cams can i just call it good? I know the pistons are diffrent for the turbos, and theres higher compression, but does it even matter? Maybe the N/t would be better because it has a higher compression?
1996 Misubishi Eclipse GSX
New school body...Old school 6 Bolt
100% stock, because cars are the worst investment ever.
Old 10-20-2005, 05:03 AM
SLoe's Avatar
SLoe SLoe is offline
Re: Can i put a 6Bolt 92 n/t in my turbo and change the cams?
You don't want higher compression when using a turbo. The turbo compresses the air already. The NT pistons will hurt you, not help. You probably wouldn't be able to boost more than 5 or 6 psi without grenading the engine. The stock replacement ITM pistons and rings will only cost you $150.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 10-20-2005, 09:19 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
For some odd reason, it dosn't sound like a good idea to me.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-20-2005, 01:40 PM
I thought i heard of someone doing that and running just fine, I'm not going to be beating the crap out of my DSM yet. I just want the thing to run.
Old 10-20-2005, 04:53 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
i put a turbo on my gs its not done yet im leaving the cams and pistons as are to see how it goes im just going to run stock boost for now until i get a manual boost controller. ill let you know it should be running in a few days.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 10-25-2005, 11:17 PM
Let me know thanks
