| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
I Need 4 Gauge Wire!!!
I need 4 gauge wire for my power and ground for my amp, which local stores would have 4 gauge wire?
Re: I Need 4 Gauge Wire!!!
any car audio shop
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
4 guage wire is 4 guage wire, even a hardware store would have it, and probably even cheaper than an audio store.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Home Depot Special
![]() not the most flexible but all copper 4 guage conducts the same so if you are pinching pennies pau $0.70 per foor instead of $3+ a foot. |
i can use regular wire like that?
would ace hardware have it? |
Hardware store cable blows ass, it has like 5 strands and you need a damn vice to bend it to the shape you want. If you're going to go the cheap way out at least get welding cable (local welding shop or from www.weldingsupply.com)
i had no problem, it holds its shape well, especially 1/0
depends on the hardware store I guess. My local hardware store sells the flexable thicker guage wire. Not the crap that has 5 solid copper strands in it that doesnt bend without a vice. Just as long as it has enough coating on it so if it gets pinched somewhere it doesnt short out too easily.
whats ure local hardware store
um, bumper to bumper/(I forget now,) I think ace hardware, or is it a kaz, or klatt, I'm not sure anymore, I'll drive by there once and find out.
Hell walmart sell a kit for 20 bucks. If your after some wire then go to autozone they have wire for a good price, harware stores but the welding supply would be the best its extremely flexible becasue of the current that it has to carry and the heat that it can generate. JCwhitney sells it in 25, 50 and 100 foot spools, so does summit and ebay should have it even cheaper.
Cant remember who posted it but if you see it give yourself credit Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota. Cardomain |
the kit at walmart for 20 bucks is what i have, it onyl has 8 gauge, the 25 dollar kit has 4 or so
ill check autozone autozones site didnt have anythin below 10 gauge
Walmart's wiring kits aren't very good. Their wire is smaller than specified and has a very thick jacket to make it appear better. In fact the cross sectional area of copper in their 4awg wire is very similar to that of real 8awg wire. Just be wary using it, wire is wire pretty much, but not when they're different sizes.
should i just buy it online? how is this?
I know knukonceptz is good, but is this wire right? http://www.knukonceptz.com/productDe...?prodID=KOL4YE cheapest 4 gauge they have (im guesisng its 99 cents instead of 1.04 like the other one cuz yellow isnt very popular?) ya the blue one want has like 1058 strands, that has 2000 whatever so is that good? cna i use that as a ground wire also? how big do i need about 25 feet? (ground should be around 3 feet right?) i need more than 17 feet for the power |
You could get that if you wanted. I'm not a fan of knukonceptz personally, they make cheap, crappy products that fall apart. Their wire is fine though, it's hard to screw up wire. If you're planning on getting the rest of the stuff with it (fuse holder, fuses, distro, rcas, etc) then I would go elsewhere. I personally use www.darvex.com and stick to Stinger equipment (except for fuse holders and distros normally, there is cheaper out there that is just as good, as long as it doesn't fall apart like knu).
