Old 10-19-2005, 11:32 PM
Buick91 Buick91 is offline
Starting problem 91 Buick PA
Hello all,
I have read thriugh many of the posts and thanks for the info so far. I am new to the car, so they help.
Replaced starter. Intermittant non start. Usually when wet out. Starter will not engage. Verified it is not a week battery. Ran jumper from battery to solenoid. Turns over, but will not start. Pull fuse number six, re install and it starts right up. Must be the resistor in the key ( I have been reading :-)). I will investigate further. Simply pulling the 15 amp ignition key and putting it back in got me home. Am I on the right track?
Thanks
Old 01-09-2006, 09:01 PM
Re: Starting problem 91 Buick PA
I have since realized that pulling the fuse only took time which allowed the VATS to reset and when I tried again after a few minutes, it worked. The solution the nest time it happened was to wait and try again. When it gets warmer I will look into putting in a resistor.
Thanks
Originally Posted by Buick91
Hello all,
Thanks
Old 01-10-2006, 09:39 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Your doing good for a Buick newbie! I don't think the dealer could do any better. If you have an extra key, try it first, or if not, get a new key made from the one you have. They cost between 15-20 bucks at most locksmith shops. If you do the resistor thing, it will disable the VATS. I guess the requirement for having that feature depends on where you live & park @ work.
By the way, welcome to the forum!
Old 01-10-2006, 10:01 PM
gottabike gottabike is offline
Send a message via MSN to gottabike Send a message via Yahoo to gottabike
I have done the vats bypass on my vehicle with no major problems. It does disable the starter/fuel kill but not the alarm system. If you decide to go with it please feel free to message me. I will be more than glad to help....
Old 01-13-2006, 04:27 PM
Re: Re: Starting problem 91 Buick PA
Thanks,
I like the car. I find the forum very interesting and useful. As I get more familiar with the car, I hape to contribute as well.
Old 01-13-2006, 06:48 PM
HotZ28's Avatar
AF Moderator Elite
A couple of links below that will help you understand the VATS system & how to bypass it, if you should choose to go that route.
I remember once, I had the same problem as you. Rather than bypass the system, I had a spare key made to keep it in the console, in the event it is ever needed. (I also keep another spare at home). I assume, I put the key in the ignition in a hurry and it did not read the resistor. That "one time" problem has never reappeared!
http://www.motorage.com/motorage/dat...09/article.pdf
http://www.12vp.com/info_resistors.htm
