Old 10-19-2005, 11:21 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
Burnouts!
hey i hav a 2001 Silverado LS extended cab 4x4. It has a 4.8L engine and the transfer case for the 4x4 is mounted on the floor. Does anyone know if this truck has positrac?? When doing burnouts, sometimes i can get both tires to spin but most of the time its only one. Usually if i gradually apply gas i can get both of them to spin but if i floor it i only leave one strip. My friend has the same truck except with a 5.3L but he can get both tires to light up EVERY SINGLE TIME! nomatter what he does(taps it, floors it, gradually gives gas, etc.) i bought the truck used so maybe the differential is just messed up?? but if anyone knows anything about posi trac or anything that can help me get both tires to light up then please reply. Is there a cheap solution?
Old 10-19-2005, 11:32 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
My '92 has an open differential and I've been able to get both tires to spin before too, but generally it's just the passenger side tire.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 10-19-2005, 11:50 PM
clayton04chevy clayton04chevy is offline
Send a message via AIM to clayton04chevy
Re: Burnouts!
i got the same problem
2004 Chevy Silverado, 2002 Chevy Camaro Z28
4.8L V8, 5.7L V8 6-speed
Truck-Flowmaster 40 series 3.5" Tips, Car-Magnaflow, Volant CAI
K&N FIPK 77 series
Old 10-19-2005, 11:55 PM
Re: Burnouts!
does anyone know how to make both tires light up without paying 900$ for the posi?? my friend said i could get the gears welded together but i wanna be able to go around corners without squeeling.
Old 10-20-2005, 07:19 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Burnouts!
See if you can find a junkyard rearend with the G80, like one from a Z71. Mine both spin every time, even is one is off the ground.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-20-2005, 07:20 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Burnouts!
Check in your glove compartment to see if you have RPO code G80. G*) is the code for a locking rear differential
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 10-20-2005, 09:29 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Re: Burnouts!
Yea, getting one of a Z71 from a junk yard seems like it would be the cheapest thing. Thats what im probly gonna do. But that is a locker, not a posi......by the way, can anyone tell me WTF the difference is between the 2?
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 10-20-2005, 09:48 AM
nathank's Avatar
nathank nathank is offline
Re: Re: Burnouts!
Do not do this. That would get old QUICK. Sacrificing driveability for being able to do burnouts.
Also, its a 4x4, why the heck are you doing burnouts anyway?
99 Z71
00 Tahoe LT
Old 10-20-2005, 10:05 AM
jeverett's Avatar
Re: Re: Re: Burnouts!
The same reason I do!!! Because I can! And it looks cool too.
A true locker and posi are basically the same thing. The G80 is a Limited slip differential if I'm not mistaken. The difference is...the LSD will supposedly take power from the wheel with the least traction and give it to the wheel with the most, therefore making it possible to move. A true posi trac, or locker (like detriot for example) locks both axle shafts together much like a spool when your going straight, but then in turns they will unlock with a loud clunk and allow the rear tires to turn at different speeds making it easier to turn and reduce tire wear.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-20-2005, 11:40 AM
Nigel215's Avatar
Re: Re: Re: Re: Burnouts!
allrighty then.. Thanks for clearing that up
Old 10-20-2005, 12:18 PM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Burnouts!
I've seen guys install sprayers in the Fender wells just in front of the rear tires. It's sprays a fine coat of water, bleech, or slippery lubricant on to the tire. You just spray a bit on for a couple of tire rotations and your good to go. Popular in Burnout Competitions or show cars. Basically the squirters are like your window washer sprayers just mounted in the fender...
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 10-20-2005, 08:18 PM
Re: Burnouts!
i went to a junkyard but unfortunatly they didnt hav any wrecked newer trucks. so i went to another place and they didnt hav any G80's either but the guy told me that he could order a brand new one in and hav it installed for 900 but he said that the genuine gm posi is weak and that he could put in a better quality one in for 1000. but i still dont hav that kind of money! any other suggestions??? o ya and wut are those fender sprayers that chuck16 is talking about??
Old 10-20-2005, 10:05 PM
No, the G80 is a locker http://traction.eaton.com/prod2.htm
I know I like to keep my books and lunch in there
Old 10-21-2005, 07:20 AM
jeverett's Avatar
Re: Burnouts!
My bad. I thought it was a LSD.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-21-2005, 08:52 AM
gremlin96 gremlin96 is offline
Re: Re: Burnouts!
you have seen the cars at the race track do burn outs with lots of smoke. thay use bleach to get the smoke rolling. it also eats the tires up just a bit to make them softer, for better grip off the line.
the sprayers is just a window washer unit installed under the finder wells. it will let you sit in the cab and spray a bit of water or bleach mix to get the tires to brake free and spin.
