Old 10-19-2005, 10:33 PM
GTP SUPERCHARGED GTP SUPERCHARGED is offline
Send a message via AIM to GTP SUPERCHARGED Send a message via MSN to GTP SUPERCHARGED
tranny
I got a 98 gtp is it possible to drop a standard tranny in it? if so has anybody done it??
Old 10-19-2005, 11:17 PM
jessep28's Avatar
jessep28 jessep28 is offline
Re: tranny
Why? The standard transmission is not designed to handle the extra horsepower.
00' Pontiac Grand Prix GT
83,500 mi
Old 10-20-2005, 03:25 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: tranny
The GTP uses the 4T65E-HD transmission due to the horsepower produced by the supercharged engine. You can put one from a na 3.8 in the GTP and you shouldn't have too many issues, in fact the gear ratio is different and can give you a performance advantage. If you want a high performance transmission check out the one from ZZP.
Old 10-20-2005, 08:24 PM
Re: tranny
yeah i always thought that a standard transmission gave you a performance advantage over a manual
Old 10-20-2005, 09:09 PM
troy1 troy1 is offline
AF -Advisor
Re: tranny
I would just stay with the auto putting a manual in would be a pain. mounts, axles, cables, all the interior mods plus the plumbing for the hydraulic clutch. You could stay with the 4T65E HD or you could use the plain 4T65E. The only thing that is HD about it is the Diff. and the related components in that general area and possibly the final drive ratio. The clutch packs are all the same and so is the general stack up of the unit. the durability is somewhat improved. Also you could have a different drive/driven sprocket ratio if you don’t find the correct match if you don’t have it rebuilt.
