Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-19-2005, 09:16 PM
GEOFFINKSTER GEOFFINKSTER is offline
Thumbs down no horse power
bought a 94 stang with a 3.8L it only has 48,000 km on it . car has no horse power , rebuilt the engine and installed custom dual exhaust bbk 56 mm b-body , super chip , under drives , bbk cold air kit . with a g-tech only has 92hp . no change from when i first bought the car. Car has a/t with a stage II shift kit . with a scaner there is no codes, engine runs great but has soon as you crack the throttle it gasps for air , very poor throttle response. All injectors work , fuel pressure is 36psi , base timing is 22 deg, Ford said the car has 190HP.
Old 10-21-2005, 06:13 PM
camaroincal camaroincal is offline
Send a message via Yahoo to camaroincal
Re: no horse power
Aren't 94 Stang 3.8's rated around 150 hp?
Old 10-21-2005, 09:17 PM
Kathmandu Kathmandu is offline
My '95 is rated at 150hp from the factory according to my owner's manual and my Hayes manual. Once I put on Cobra style rims and tires I imagine my gear ratios changed enough to drop 20 hp from the final drive.
I would say the 3.8 is about as tuned as its going to get from the factory. I would have spent the money and got a 60's model 302 and dropped it in if I wanted a hot car.
Old 10-22-2005, 08:52 PM
navajo50 navajo50 is offline
Re: no horse power
base timing factory should be 10 degrees btdc . you can make it about 12 degrees and they will gain you some i think 22 would cause loss because of detonatin .{valve ping} try cleaning your injectors with a iv bottle that may help.
Old 10-22-2005, 09:01 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: no horse power
92hp? holy hell my escort made 116hp
a typical stock manual 94-98 3.8 should be around 123
