Old 10-19-2005, 09:10 PM
THE GHOUL THE GHOUL is offline
85 F150 gear ratio
i wonderin if anybody knew the gear ratio on a 85 F150, the sticker that has it on there is gone so i cant tell. its completly stock rear end and geared low so i need a ring and pinion set for it
Old 10-20-2005, 03:09 PM
badasstour badasstour is offline
Re: 85 F150 gear ratio
does it have a stick in it and does it have the tag on the rear end if it does take it in to a auto parts store and they can help you the sticker in the door jam still there if it is get the axle code and i can tell you what the rotio is
Old 10-20-2005, 06:11 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
You can count teeth on the ring gear, then count teeth on pinion, then divide number of pinion teeth into ring gear teeth. This will give the ratio. Example, ring gear 54 teeth pinion 16 teeth
48 divided by 16 equals 3.50
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
