blown fuse on 03 bonneville interior lights
Help. I keep blowing the fuse on my interior lights and have replaced the relay for the lights also. I took it to the dealer ( my warranty is about to run out) and all they did was place a larger fuse in it and it blew also, they said the only thing else to do was tear the interior out and check the wiring. Has any one had this problem and has another possible solution.
Thanks |
Re: blown fuse on 03 bonneville interior lights
Let em do what they have to!
I am still having the same problem. The interior lights fuse blows. Sometimes I replace the fuse and it will go for 4-6 months. Then I will have to replace it daily or weekly for a month. Then it will not blow for another few months. Has anyone had this problem and where did you find the problem? Also, where can I get the wiring diagram without buying the entire book?
Thanks for the help! |
You can get pretty good WDs at the following website:
http://www.ahdol.com/ There are a couple ground busses you might check and clean, then use dielectric grease on during reassembly. They are by each front door below the carpet. The buss is usually taped to a large wire loom that runs along the rocker panel. Each buss is very near the front of each front door. Check this link to see pics of where these busses are. http://www.bonnevilleclub.com/forum/...=article&k=102 Hope this helps.
1995 Bonneville 3.8L K, 125k and still going. 1996 Bonneville 3.8L K, 156k and still going. 1997 Bonneville 3.8L K, 147k and still going. 1998 Dodge RAM 2500 5.9L Cummins Mechanical, 107k and just startin'. |
I have the same problem with my 03 Bonneville. Blows fuzes on interior lighting. Relay is good. Light side of fuze holder is shorted to ground. I checked each light bulb socket and switch. Does anyone know where this ground short might be? Is this a common problem for this model?
i have a 05 grand prix..with same prolem..anybody find a cure...sometimes stays werkin for a month next might be two days..thought 1st was rain related but isnt
any updates on these ??? the 05 grandprix has gottin worse as to now she cant put a fuse in n it will blow...so where evo the short is its gottin bearer..time ta start pullin panels n carpet i rekon
update on my 05 grand prix...started follow wires from front ta rear...yanked rear seat n found the short...right as wires enter hole to trunk..couldnt see jus felt nick in harness...so pulled back a tad n taped n tried fuse n wala..lights werk n fuse (of course) dint blow.. i r a happy camper again paps
