Old 10-19-2005, 08:01 PM
flip4life666 flip4life666 is offline
bench seat to bucket seats conversion
I own a 93 s10 with a bench seat. I was wondering if it is possible to swap out the bench and put in bucket seats. The truck is not an extended cab. thanks
Old 10-20-2005, 01:16 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: bench seat to bucket seats conversion
did it in my 98, 3 of 4 bolts lined right up and literally bolted right in, only fab i did was i made a steel spacer, and took flat stock and drilled 2 holes in it so i could bolt one end of stock to seat and one end to truck floor, not a direct fit, not bad
Old 10-21-2005, 12:35 PM
i_cry_at_night's Avatar
i_cry_at_night i_cry_at_night is offline
Send a message via AIM to i_cry_at_night
i did it in my 95, all i had to do was switch the rails and everything worked perfect...
'95 S-10 and '52 MG TD
Old 10-23-2005, 02:26 PM
didnt switch the rails... wanted to sell the seat
Old 10-23-2005, 09:55 PM
well mine fits perfectly and i trashed the bench seat... does anyone know if its legal to put seats in the bed?... i doubt it but maybe some roll bars and seat belts might legalize it maybe not
Old 10-23-2005, 10:27 PM
rdfirbird92 rdfirbird92 is offline
Send a message via Yahoo to rdfirbird92
what seats did all of you end up using? I want to do a seat swap, but cant find anything cheap enough
01 dodge stratus R/T 3.0L v6 5spd
underdrive crank pulley, Eibach Sportlines
Fidanza stage 3 clutch, Fidanza lightweight flywheel NO MUFFLER
http://s72.photobucket.com/albums/i1...mperfixed2.jpg
R.I.P. 12/19/05
'98 s-10 2.2L 5spd daily driver
2/3" drop, K&N filter
Pacesetter header
high-flow metallic cat.
flowmaster 40 series
BFG G-Force T/A KD's
Old 10-24-2005, 02:26 PM
go to a salvage yard, i got both of mine for $50
Old 10-24-2005, 10:58 PM
in Michigan as long as there are seat belts, it is leagal to have seats in the back of a truck, foward or rear facing
ps, i assumed, but i should mention, that the seats and belts must be fastend to the truck and not just floating
Old 10-25-2005, 09:58 AM
BLAZERBOY69 BLAZERBOY69 is offline
My Little Brother Took An Old Recliner, Unscrewed The Foot Pegs, And Then Drilled Four Holes In His Bed, And Used Four 3 1/2 Inch Bolts To Attach The Recliner To His Bed. He's Got A 90 That Has Been Through Hell And Back, But When We Go Fishing, We Get Into Fights About Who Gets The Truck Chair.
Old 11-28-2005, 05:25 PM
AdAmN20 AdAmN20 is offline
I have an 87 S10 and I did a seat swap with a 2003 S10... 3 or 4 bolts lined up.. just make sure you get new seat belts...
Old 11-29-2005, 08:37 PM
has everybody just swapped with another s-10? I LOVE the seats in my firebird, but i dont know how much trouble they'd be to put in.
R.I.P. 12/19/05
Pacesetter header
Old 11-30-2005, 08:37 PM
The easiest thing I suggest is get 2 pieces of wood for each seat and mount the wood to your floor, then mount the seats to the wood... I started to do that with a set of seats out of 03' S10, but the seats bolted right up .
1987 S10
17" Eagle Alloy's
245/45/ZR17 Sumitomo Tires
AirRaid Cold Air Intake
3.4 L Camaro Conversion Engine
Flowmaster 40 Series Muffler w/ turndown
Check Mate Flush Mount Bed Cover
2006 Silverado Crew Cab 2wd
Blue Granite Metallic w/ Charcoal Interior
4.8 Vortec
Magnaflow Exhaust w/ Dual Turndowns
Old 11-30-2005, 08:41 PM
dave350 dave350 is offline
im also looking to do that in my 91 s10. buckets out of a 90 cavalier are awesome, but i dont know if theyd fit
Old 02-07-2006, 02:52 PM
daveholiday daveholiday is offline
does anyone have any idea how to put bucket seats in the back of a car, in place of the bench seats?
